painting case
I have a antec performance plus, grey case steal panels and plastic front, what would be the best way of going about painting this, things i need and what to use?
Have you checked the casemod faq? Plenty of information about case painting there.
First Off Its A Lot Easier To Paint It About The Same Color Or Have Two Colors. The Front Is The Hardest Part.
Take Everything Off And Lay It Out.
Get Your Paint And Spray. Do One Piece At A Time And Let It Dry To See If You Like. If So Finish The Rest. If Not Then You Didnt Waste Time.
READ FAQ BEFORE POSTING PEOPLE. Does it need to be flashing or something for everyone to notice? :mad:
Primer
Paint
Clearcoat
If you dont wish to research, thats all the help I can give you :p :D
You know, it's customary to capitalize the first word of a sentence and proper nouns.
Primer
Paint
Clearcoat
If you dont wish to research, thats all the help I can give you:D
They Need To Get Somthing Like That. Have A Flashing Mod :)
I Type How I Type
People Just Leave Me Alone :(
