Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
As already mentioned, painting fans is do-able. However, I don't think you will get that great of a metal effect. The majority of the metallic paints out there are nothing like the real thing. Good luck though! Be sure to show us some pics if you are successful.
I think the aluminum housing fans will give you bettter results than the metalic colored painted ones. I wasnt impressed with the metalic paint I tried. IT actually turned into a disaster when I tried to polish it out.
