painting acrylic
Im looking to paint one of my panels on my acrylic case, are their any paints that i can see through so i can still see my components?
well there is vinyl dye...
but... if I had an acrylic case, I would tint it. Go get some car window tint at a car store and put that on.
kinda defeats the purpose of an acrylic case, but im thinking about putting a gloss fininsh on all but the side panel of the case, any other ideas?
paint it with any "candy" clear coat and it will be tinted in the color of your choice, or mix some black paint with the clear like 25 to 1 ratio to make your own spray on tint.
