Painted the inside shell
speedx
Well I have had this case for about 5 years now .. it was that off white before. i painted the outside black and i finally got around to painting the inside shell.. more pics soon
Looks good. I love that color of grey. I think I may have to paint the inside of my case that same color.
what paint is that? did you primer it first?
looks good - much better then other painted chassis i've seen. ;)
It is bumper paint, flat black nothing special. I just had it laying around so I tested it and it looked ok so I said what the hay. I did spray a coat of grey primer on first.
Thats nice, a friend of mine has that same mobo. I'm starting to plan painting my case this summer, might go for black interior or red, dunno. But i'm starting to lean towards black after seeing this :)
That frame has some sexy curves in the inside corner pieces. Very stylish with the flat black.
A outide pic, if you guys been around this forum for awhile you might have seen my case years ago.
Okay, now paint the drives! I even did it on my DVD burner on the gateway at work! ;)
Stupid HP grey drives....
Nonetheless, it looks good.
Ive got the same exact internals inmy case....its totally modded and painted kinda like that....the hardest thing with the internals was getting every little hidden spot. But im please with it and hope to have pix up very soon. My main side is one big piece of plexi though... No one seem to carry these cases nemore to get just a side. Good job by the way. Paint looks awesome.
Im going to do the stealth drive thing, i dont like painting drives, just incase i sell it.
Got it from canadian tire - but im sure any flat black paint will look ok. Make sure you dont try to paint the whole thing in 1 shot do a light coat then another to make it all covered then I did 1 more coat. Also did a grey primer before, the hardest was the corners and the tight spots, I have a few pc's so I was in no rush. The inside is the flat, the outside is a silk black, I guess that's like semi gloss?
that looks really nice.
reminds me of the cases that the computers at my high school were like, just twice as big and painted
