Paint stripper for plastics?
SticKx911
Does anyone have a recommendation for a chemical that will remove paint from a textured plastic surface? (ie just sanding will harm the surface)
media blast with baking soda...
Turpentine, acetone, goo gone will all eat the plastic your going to be stuck with media blasting it with something softer than it or you could try heat and rubbing alcohol but be very careful with the heat most plastics melt before paint does...
