qpwoeiruty
- Jan 30, 2006
Hi to all!! I'm trying to paint the interior of my CM Stacker (using a Motip silver metallic spray can), and i'm facing a somewhat serious problem. There seems to be a lot of dust particles sitting on my paint just after spraying, screwing my job. It seems to happen, whatever i do, even if i clean the area i'm working. Working outdoors is still a problem. As you can understand, i cannot sand the metallic paint, so... do you have any suggestion on how to avoid that? Is there any antistatic trick i can do?
