Jan 26, 2004 #1 M MDboyz Limp Gawd Joined May 2, 2002 Messages 307 I'm looking for where to buy the paints for plexi-glass/arcylic? Is there a special paint for it.. or I can just use any paint?
Jan 26, 2004 #2 A Acceptable_Risk [H]ard|Gawd Joined Aug 23, 2001 Messages 1,973 Vinyl dye should work pretty well. Barring that, a spray paint oriented towards plastics is probably the best option. Check out Krylon Fusion.
