Hey all, been lurking for a few weeks and decided, on a whim, to do a paint job on my old Toshiba Satellite 1135. After taking it apart, ect. I did a white base coat with Krylon Fusion - it looked pretty good and after a few coats i let it dry then taped it to do a couple of black stripes down the front with a can of American Tradition Plastic Enamel.
The problem is, about half a minute after i sprayed the black down, it started cracking against the white and i dont' know why. Don't know if it's because it's two different brands, didn't clean it well enough before i applied the black or what. Anybody seen/ heard of this before? and if so, what should i do to fix it?
