paint concern please help
AY786
im going for a glossy black mirror paint job on my case and am on the stage of applying the last primer coat before painting. However, the primer im using is an self etching primer and the colour is like a creamy yellow. Will this affect the gloss do you think or should it be fine?
Please help, thanks
Self-etching primer is not meant to be used like a regular primer. 2 coats of it and then you can spray your basecoat right over it. No sanding necessary. Just FYI.
The color of it wont make a difference assuming you put enough of the base color over it.
