paint choice
XtuRmN8r
I am currently modding an old style lanboy, I've already cut out that horribly restrictive lower part of the front bezel, and now the front is home to a 120mm alu. fan, and behind it a BI extreme 120mm Rad. I am going to purchase some modders mesh type stuff, and hopefully it turns out as a good front grill.
My question to you is, I'm planning on a solid stripe from top to bottom on the front bezel, as well as on the top of the case. Would you guys go for a blue (like chuckle's xbox, "True Blue Pearl RC Car Paint") or would you go for a glossy black? I am also planning on doing the PSone LCD mod, and sticking that on the door, if that alters anyone's choice.
Thanks for your opinions.
**edit, also, would I need to prep the surfaces any different to make the paint stick, like sand the top paint, and use some other technique on the plastic door / modders mesh?
