Paint chipping
CHAoS_NiNJA
I love modding cases, but one thing I hate, and I mean hate...is painting. Why, you ask? Well, for one, chipping. My current case is covered with unsightly nicks and chips....and I have no idea how to stop it. I thought about clear coat, but I've been told that'll ruin the paint somehow. Can someone give me some pointers?
Clear coat does not run if you apply it lightly ... follow the directions ..
You have to let paint cure .. it takes atleast 3 days ... be patient and you'll get the results you're looking for ..
He said RUIN not RUN.
Also, if you use the same type of clear as the paint you should get good results. Mixing types of paint will only lead to grief. Of course, YMMV. I had a case where I used the wrong kind of clear coat with the paint I was using and it wrinkled. But it created a really neat crackled effect, that worked out just fine. I just put on several more coats of the clear and it worked just fine.
Good luck, show us some pics if you have some. Are you talking about chips from regular use and accidentally hitting it with stuff, or does it come off in big chips as if it were peeling?
Clear is short for Clearcoat.
Essentially, it's a transparent coat of paint that layers over your paint protecting it. You can choose a glossy, shiny, colored, mat, etc etc clearcoat depending on what you're going for. If you have a paint gun, you can color your clears for added effects. (candy apple, anyone?)
Now it's important to choose a clearcoat that is compatible with your paint. If you're not sure, test it before you paint your case! I've seen awesome paint jobs bubble after applying non-compatible clears over some paints types. If you're using automotive-grade paint and the same company's clear, you shouldn't run into any problems but again, test it if it's not the same line/quality. Do NOT clear over your current paint. For one, the clear will look like crap as it will "sink" into your current dings and scratches and the current paint job will most likely not be compatible with the cleanrcoat. You're much better off re-painting you whole case.
When applying clear, always go with several (if not dozen) very light coats to avoid drips and runs. Allow it to cure properly for a few days and follow up by water sanding and high-grit compounding to bring to a pimp shine.
Hope this helps you out a bit.
