Hey all,
I just started building a new computer yesterday and I had everything together and working last night. I moved my 3 year old IDE hard drive over from my old computer and put it in the new build and it was fine and dandy. This morning I turned the computer on and immediately got an error message saying "boot drive inaccessible". I checked the connections on the hard drive and they were fine. Rebooted and got the same error message. Rebooted again and the comp no longer detects the hard drive. I hooked it back up to the old computer and it's obviously not spinning anymore at all. I then checked another hard drive in the new build and it works just fine. I'm guessing the 3-year-old drive is permanently dead, but what I need to know is could I have done something to kill it? Or does it sound like it might have been failing anyway? This is only my 6th build or so (and the first one in 5 years), so I'm afraid I may have done something wrong to kill the drive.
Also, I intended to put an older hard drive in the old computer and move it downstairs for my dad to use. I installed the older drive, moved the computer downstairs and checked it out and it worked fine except I had set a CD drive as slave when it should have been master. So I shut down, fixed it, and plugged the computer in and hit the switch and....nothing. No power whatsoever, just like that. The power supply fan doesn't even spin. I seriously don't think I could have done anything, but it's very odd that two things have just up and died so soon after I've messed with them in the same day. Did the power supply just die all of a sudden? And if it did, why? Or could it be something other than the power supply? (though I can't imagine what...)
If anyone can think of anything, please let me know, because I am quickly going insane dealing with this stuff....
Thanks,
Dmwc
Thanks,
Dmwc
