D
Deleted member 12106
Guest
Your optical drive is lame.
USB FTW.
That is all![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![2012-05-23%2018.23.21%20(Medium).jpg](http://www.sc0tty8.doesntexist.org/pics/network/2012-05-23%2018.23.21%20(Medium).jpg)
USB FTW.
That is all
Uh, I dont think thats a sonicwall, isnt that the fort?
lol.Nice box Scotty, but now I have found pfsense and I kind of love it. Though now im not running anything.
Yeah the box with antennas is a fortiwifi.
Show me a study that a 2.5 will save heat over the 3.5 Also out of the box this has no mounting holes for a 2.5 and this is for a project so I am not going to jimmy rig it. I've got my eye on another intel/atom board I'd like to use at the house but there are no performance issues whatsoever on my sempron untangle box.
I dont know that heat production, in this case, has as much to do with how it is removed from the case, and if it is a single drive, it really should not matter as far as I can tell.
Consider this machine as a server (If its business) will be in an air conditioned environment, and furthermore if its where scotty works, a business not admined by a nettard, and hence will be fine.
Just a random thought
a fan at someplace in the case would definitely be good, but why not simply put like an 80mm fan or something in near the board blowing over the board? As long as theres "a" fan removing heat from the main component area he should be fine in theory, its just an atom board.
Hey I got that exact Supermicro server, well at least the case part.I use it for my hvac control and eventually network/environmental monitoring.
I usually use the management interface and load an ISO through there for OS install. The first time I did it I used a USB cdrom drive. Did not even realize it had a management interface till later. Nice little server.
For fan what I did is I added a 9000rpm 60mm one on the back, turned out the vibration caused the drive to stop working, so I put it on the 5v rail. It's quiet too, and still moves some air. The psu has it's own fan but left alone it would not remove from the component area. Dash, where do you find those blower fans? They look like they would work nice for high static pressure situations.
