PA120.3 Fitting?
iLLuSioN
I just got in my PA120.3 and I was expecting no screws cause I bought 2 bitspower 90 degree 3/8 5/8 compression fittings...however they don't fit... what am I missing here those fittings weren't cheap which do I need?
Thermochill radiators use G3/8 fittings. Most normal fittings are G1/4. You either need to get special G3/8 fittings, or just get a converter that will convert from the larger G3/8 down to G1/4.
