MasterplayerC
- Feb 24, 2009
Might not be computer audio, but everyone here seems pretty knowledgeable so I figure it can't hurt to ask.
My band is playing a show on Friday and we have pieced together a PA system that we want to try and optimize.
We have a 6 channel mixer, power amp, and PA head with built in 6 channel mixer. The power amp and PA head each have 2 speaker outputs.
We have two big main PA speakers with both a speaker and a tweeter, and two smaller PA speakers that we either want to use as monitors or as extra output.
The two big mains have both a low and high input on the back (speaker/tweeter), as well as 2 parallel jacks. The monitors just have one input.
Would it be possible for us to use the parallel jacks on the backs of the big mains to daisy chain the monitors? Neither the mains nor the monitors are powered.
We're currently running inputs into the mixer, and then from AUX send on the mixer to the power amp, and the big speakers out of the power amp (but only through the low input, neglecting the high). And then from the L/R main output on the mixer to channels 1 and 2 on the PA head, and out of the PA to the monitors.
We're basically trying to maximize sound while using as few cables as possible.
The gear for reference (as best as I could find):
Mixer: http://www.behringer.com/EN/Products/MX602A.aspx
Power amp: http://www.markbass.it/products.php?lingua=en&cat=1&vedi=82
PA head (ignore the speakers, we dont have them): http://pro-audio.musiciansfriend.com/product/Kustom-PA-Profile-One-PA-System?sku=630506
Monitors: http://www.audio-choice.com/speakers/ac10tbot.htm
Mains: cant find them
Any help would be greatly appreciated.
