I was wondering if someone knew what the different "straps" are on the Asus P5B (P965). Someone has some data on it:
and link: http://www.bleedinedgesupport.com/ocz/forum/showthread.php?t=23803
I was wondering if anyone else has done some testing, it appears that the Asus p5b goes into the 1333 strap at 401fsb, because memory bandwith continues to rise from 266fsb up till 400fsb.. but then drops down to 333fsb levels at 401fsb..
i am trying to decide whether it is worth it to attempt going higher than 3.2ghz.. i think my proc can do 3.6ghz considering my temps and voltage @ 3.2ghz (35-46C idle 1.303V, 47-58C load 1.248V) (yeah ambient temp changes in my room alot, its hot here.. and i don't always have AC on).
I most likely will have to change my RAM to cas5, currently 4-4-4-12, which is another factor...
