Mar 13, 2008 #1 D delvryboy 2[H]4U Joined Feb 21, 2008 Messages 2,486 Does Prime95 have a program that works with Ubuntu? Also could use a temp and cpu-z type program. Thanks
Mar 13, 2008 #2 A ac50186 n00b Joined Sep 9, 2005 Messages 8 The linux version of Prime95 is called Mprime. If you need temp monitoring, check out GKrellM. I've used both; they're excellent programs. Mprime runs from a binary download, and GKrellM is available in the repositories. Good luck.
