I just built a system using an ASUS P8Z68-M Pro motherboard and an i5 2500K. It has 4 Gigs of Corsair memory and right now is running on a 30 Gig SSD paired with a WD Green 1 Terabyte hard drive using the Intel Smart Response Technology. Its running Windows 7 X6x Ultimate and the system works just fine. I have it hooked up to a home network through Cat5 cable to a Trendnet Gigabyte Switch that feeds my Core i7 2600K gaming machine and a Patriot Box for streaming to my television. The gigabyte switch is connected to a Netgear Wireless N router that connects to my Dell XPS laptop and the modem for my Road Runner broadband. Ive never had any trouble with any of the systems hooked up to this network but the P8Z68 doesnt seem to want to stay in sleep mode. It will go into sleep but then comes out anywhere from 10 seconds to 10 minutes later. The system is not overclocked and all settings are set at the default except for the memory which is set to the rated speed of 1600. By the way, I was running it earlier with a 60Gig SSD as a boot drive and a 2 Terabyte Samsung hard drive and the problem was the same.
Ive gotten on the Internet and checked out this problem and done everything that was suggested but to no avail. Funny thing is that if I disconnect the network cable then the system will go into sleep mode properly and stay there. That tells me its a network problem but I cant seem to find any settings in the BIOs to change the sleep settings like on my older machines.
I use this machine for general office tasks, downloading and surfing the Internet and I need it to be able to enter sleep mode when its not being used. Anybody have any suggestions?
