P8Z68-V PRO Problems
jimeyre
Hiya,
I have spent time searching this forum for answers to my problems but am unable to pinpoint an anwer to my questions. I have built PC's on and off for the past 10 years and never had problems like this!
Heres my problem
1. I purchased an ASUS P8Z68-V PRO, set everything up and plugged in my old Win7 install on SSD.
2. Fired here up, mobo would post (great) and I could access bios settings.
3. When booting up, windows7 would begin to load (for 2 seconds) then the system would throw an error. The error seemed to vary between a kernel issue and an bootmgr.efi file issue.
4. I did not have internet access or an ubuntu os disk to hand (so can't boot into that to check the new hardware is working correctly) as my pc was obviously not wokring so stupidly I began to fire at shadows!! From here, things go down hill!
5. Win7 Repair mode fails repeatedly.
6. I access dos cmnd prompt and format the ssd (diskpart)
7. Reboot, win7 setup does not start?!wtf! I get the same bootmgr.efi error. At this point it looks as though there is a problem accessing the data on the win7 disk!!
8 . I unplugged the SSD and rebooted. Same error encountered wtf!
9. I thoguht there might be a problem reading the sata DVD drive through the sata port (6gb) so I changed to the 3gb port...still no luck.
8. Now I have lost everything on my hard drive, I decide to do something even more stupid. I inserted the mobo setup CD, loaded up bios settings and selected within 'tools' update bios. The bios appeared to successfully update.
9. Reset CMOS
10. Restart....no post!! Now i am screwed.
11. I now have several problems.
- Firstly I need to somehow sort this bios issue out: Can i rollback the firmware or do I have to buy a new bios chip from Asus? (I can't go a weekend without a PC.....).
- Secondly: I have not flashed a bios in atleast 5 years or more. I no longer have a floppy drive. Is it possible to flash a bios via a USB stick or do I need some sort of USB floppy? Do the latest mobos recognise a USB controller, like it would a hard drive? I know years ago you had to flash the bios via floppy.
- Thirdly: If i get the BIOS issue sorted, if I can get back to where I was at the start of all this, what can I do to get the mobo to see the DVD drive and install Win7?
- Last but not least: This is a lesson to n00bs like me, don't play with new tech!!
Now that I am at work with net access I found this article somewhat too late:
http://hardforum.com/showthread.php?t=1609704&highlight=Asus+P8Z68-V+PRO+bios
Can anyone help, I am in a desperate panic :(
Do you have the manual?
It gives a method for recovering from a bad BIOS update. However, it requires that the machine be able to POST far enough that the utility can run. If your display never displays a message about searching for firmware, you may not be able to recover.
There are a number of ways of flashing the firmware on a P8Z68-V Pro. It can be done from within Windows. It can be done using EZ Flash, from a USB key drive, CD, floppy, or (I think) from a FAT32 hard disk. There's also a DOS utility, which I've used from a bootable USB key drive.
At a guess, you'll need the replacement firmware chip.
Let me add that I've been doing BIOS flashes for 15 years. Prior to P67/Z68, I've never managed to render a PC unbootable with one. With the new boards, I've had it happen twice. (The flash appeared to proceed normally, but the machine was left in an unrecoverable state. One of the boards was an MSI P67 one, with a nominal dual BIOS. That was zero help, as there was no way to force the board to use the backup BIOS. It was as if the new BIOS wasn't detected as corrupt, but the PC wouldn't boot from it anyway.)
Ok, thanks for the advice. I will send for a new chip.
In the meantime I've reverted to putting my old hardware back in but unable to boot up the win7 setup disk. Getting one if the same errors I got before '0xc0000001' 'The selected entry could not be loaded because the application is missing or corrupt'. So, somewhere along the lines trying to repair my old win7 install whilst running the asus z86, my win7 disk has become corrupted or my DVD drive has packed up! Great, lol!
