p8p67 pro issues - get OS, cant get BIOS
ycat
So i have an asus p8p67 pro.
Issue#1: i can boot into win7 normally. however, for some reason the splash/BIOS no longer shows up, and all i see is a black screen as everything is booting up (black to desktop). If i spam delete, it just stays at the black screen and i cant see the bios, then have to manually reboot. Not sure whats going on here. Used to be able to get into it just fine.
Issue#2: when booting, the internals spin up, but its a good 5-10sec before the initial boot beep goes off. While im waiting for the beep, its just a black screen, keyboard doesnt light up, and my monitor just keeps going from analog to digital trying to find a signal (which it does once the beep goes off).
Any ideas? using bios 1204.
2500k
corsair tx750
gtx 570
ocz vertex 2
8gb mushkin
