P8P67 +5V surge
After normal boot and load of Windows OS while idle or under stress at no particular time the computer will reboot and post the following:
Power supply surges detected during the previous power on.
ASUS Anti-Surge was triggered to protect system from unstable power supply unit.
I have completed the following;
- BIOS is loaded with all Defaults
- Memtest on each stick verified no errors
- Prime95 1 hour verified no CPU errors
- I have replaced the power supply with a PSU ANTEC TP-750 750W
- cleared CMOS
...same random, anti-surge results, with high measures from the +5V
below is a sample of the Probe II Alert Log
[04/03/2011 at 11:27 am] +5V 5.560 Abnormal
[04/03/2011 at 11:27 am] +5V 5.240 Normal
[04/03/2011 at 11:30 am] +5V 5.520 Abnormal
[04/03/2011 at 11:30 am] +5V 5.320 Normal
[04/03/2011 at 11:47 am] +5V 5.520 Abnormal
[04/03/2011 at 11:47 am] +5V 5.320 Normal
AIDA has Voltage Values in the same range.
Any thoughts on next troubleshooting steps ?
If the numbers check out and/or the motherboard sees the replacement/borrowed PSU as "defective" as well, then it's probably the motherboard sensor that is in fact defective. In that case you'll need to RMA the board if there's no way to just turn the feature off.
You can turn off the surge protection. Its doubtful that in the case of a true danger surge that it would actually act fast enough to protect the computer anyway.
