P7H55-M PRO IMC Volt Mod
That's an H55 chipset. It's going to be pretty much nil on the voltage/oc options. What exactly are you trying to do?
I'm trying to figure out a way to increase the IMC voltage with a pencil mod, or through the bios im using an i5 750 and I've hit a wall at around 3.6 ghz. I've tried just about everything to get it stable past that. The max I can set the IMC voltage to in the bios is 1.2 volts nothing more.
I found that the P7H55-M non pro shows on the ASUS website, it is able to adjust the IMC a lot finer, and has a similar hardware layout that's why im thinking a bios mod might be able to do it.
Pretty much every board in the P7H55 family has higher adjustable max then the "PRO"
P7H55-M PRO
vIMC: Adjustable IMC voltage at 0.05V increment
P7H55-M
vIMC: Adjustable IMC voltage at 0.00625V increment
