As much as I "should" I don't want to reinstall Windows, etc. Looking for something that can use my existing 2500k and ram for now but also being able to put in something newer and faster then the I believe the 3770k that is the max supported as well as using 2133 ram at a bare minimum as I guess that may also help with this older cpu!? Thanks for any 2 cents!
