P67 motherboard S3 sleep wake up problem when o/c
Discussion in 'Intel MoBos' started by harbin, Jan 17, 2011.
  1. harbin
    harbin Gawd
    929
    Jan 23, 2007
    So far, have tried 2 P67 boards. None of them works good when waking up from S3 sleep while the system is o/ced. ASUS P8P67 and Asrock Extreme4.
    Can you guys with other mobo comment on this?
    Thanks
  2. kandor
    kandor Gawd
    616
    Aug 24, 2005
    Same here, as soon as I oc'd, trying to resume from sleep results in a black screen. Sometimes, after I power off / on it will resume, other times it says 'windows did not shutdown correctly'. It's too bad because it was working great before
  3. The Mac
    The Mac [H]ardness Supreme
    4,497
    Feb 14, 2011
    its a known issue...intel is working on the problem
  4. wesleys_dad
    wesleys_dad [H]ard|Gawd
    1,271
    Jun 21, 2005
    id notify the tech support for the affected boards and they will pass the info on to the bios team..hard to say if its a chipset or bios issue...ive had sleep issues with boards before and it was always solved with updated bios...just a thought....
  5. zaxour
    zaxour [H]ard|Gawd
    1,129
    Jan 31, 2008
    Not a problem here, 4.5 GHz and I'm able to sleep the machine. However, when I had Spread Spectrum DISABLED, I was unable to reliably sleep my machine. When I re-enabled it, everything worked fine.
  6. The Mac
    4,497
    Feb 14, 2011
    the problem is caused by enabling pll overvoltage , which most people need over 4.5, if u can disable it, it should work provided nothing else odd is going on.
    again, intel is working on a solution.
  7. zaxour
    zaxour [H]ard|Gawd
    1,129
    Jan 31, 2008
    I also have PLL Overvoltage enabled, so I'm not sure that's universal.
  8. The Mac
    4,497
    Feb 14, 2011
    turn up your oc to 4.6 or 4.7, you'll have issues...
    according to gary who says intel has told them, over 4.5+pll overvolt = erratic sleep
    im sure ymmv though. probably depends on the chip binning.
    spread spectrum is a new one though..i would think disabling it would help, not enabling it...lol
  9. 123Lanoix
    123Lanoix 2[H]4U
    3,588
    Nov 13, 2005
    this doesn't make sense since i have PLL overvolt disabled and this was not an issue on my old p8p67 board
    my only assumption is that its a bios issue with 1305 or its a memory issue but my memory has worked fine on the other board and do not get any BSOD. so i guess its really a bios issue since it does some weird power cycling coming out of sleep. Maybe gary can speak about this or talk about creating a fix or running some test.
  10. aldamon
    aldamon [H]ardness Supreme
    6,446
    May 24, 2000
    I'm seeing this problem with my TP67B+ as well and of course PLL voltage override is enabled. Glad I'm not alone.
  11. RipperMac
    RipperMac Limp Gawd
    338
    Jul 20, 2002
    No problems with msip67-gd65 (see sig)
  12. Iching
    Iching [H]ard|Gawd
    1,791
    Nov 29, 2008
    Double boot issue, upping offset in BIOS and trying to exit causes a shutdown and an annoying "loop" problem. I am really disappointed with Asus. I am using latest BIOS 1502.
  13. BlueAqua
    BlueAqua Gawd
    942
    Jul 24, 2004
    At 4.5 Ghz I don't have problems with sleep, however at 4.8 I run into issues. Back it down a bit if you want sleep ability.
  14. yenniedn
    yenniedn 2[H]4U
    2,055
    Nov 26, 2007
    I had a GB b2 UD7 on 4.8 that slept and resumed without a hitch.
    I moved the same 2600k to an Asus M-IV-E and not can't wake up from sleep at all. So I know the CPU's not the issue.
  15. The Mac
    4,497
    Feb 14, 2011
    There are plenty of people with asus boards with no sleep problems, also plenty WITH sleep problems...its a crap shoot...im sure youll find the same issue with Gigabyte boards as well. People who have issues are more likely to post than those without, so it seems like there is allot, but we dont really know how many dont have issues.
    SInce Intel has admitted its a problem with the base level firmware of the Cougar Point chipset (not the Sandy Bridge CPU) we are at their whim for a solid fix.
  16. Falkentyne
    Falkentyne [H]ard|Gawd
    1,436
    Jul 19, 2000
    Turn off CPU PLL Overvoltage. Or you mean you still have the problem with it disabled?
    Maybe "Auto" sometimes enables it?
  17. Spooony
    Spooony 2[H]4U
    2,073
    Mar 9, 2011
    can you give me the Asus mobo details and the AsRock mobo details please so I can provide you with a bios.
  18. aldamon
    6,446
    May 24, 2000
    Blasphemy! I'll buy an SSD first.
