P5w-DH wont post
zidion
I took my PC apart last night to set up a new WC loops. Let it run to check for leaks, etc. I just put all the stuff back in to my PC and it wont post. It turns on and everything is running, but nothing shows up on screen. There is no beeping noise or anything.
I even took it down to bare mimimums (ram and video card) and it still wont post.
Any ideas?
Have you cleared CMOS? Reseated all your cables? Does it give you any indication of power? Have you used a volt meter to check your voltages? Reseat your memory? You might also want to pull everything out of the case and run it outside with the water cooling geat on it. That way you can determine if you might possibly have a grounding issue.
cleared CMOS-yes
Reseated cables-yes
Indication of power- green light on mobo is on, and fans connected to it power on
Reseat memory-yes
havent pulled everything out yet.
Umm, the CPU can't really move. So I doubt there is a bad connection there.
If the waterblock was removed there is always the possibility that the CPU got pulled loose... It's just a thought and takes all of about two minutes to double check soooo.......
True, but with LGA775 they don't come loose unless the arm on the socket is up or something and the cover isn't down all the way. LGA775 CPU's simply rest on top of the pins, but they are locked from moving side to side by the indentations and two tabs that fit into the slots on the sides of the processor. Then the cover holds the processor down by pressing on the edges of the heat spreader and does so from all sides.
Not really possible in my opinion.
didnt work.
Disconnect all power from the motherboard and then pull the CMOS battery. Leave it out for 20 minutes or so and then try again.
After that it's time to start swapping parts.
**Pulls foot from mouth**
True, true.... I din not know that we were discussing a 775 based system:mad:
And, it didn't work anyhow...
The first thing I usually suspect when complete failure to post is the issue is fried ram... or a dead board.
Tried that, still nothing. I think the mobo is dead. I unplugged the power from the videocard, and when I would normally turn it on it should make a loud noise. This time it Didnt.
Ouch.
pretty much means its dead rights? should I even test anything else?
You should always try other things. Swap memory, CPU, PSU's, or whatever else you need to in order to isolate the motherboard.
I was rebuilding may system into a new case and ran into the same fault.
On power up all seems normal,fans run but no post beep, no video, but after 2-3 minutes CPU fan stops and then I shut things down.
With all RAM pulled, I get a post error (1Long and 2 short). After looking around the internet I found that by pressing and holding the "insert" key after power up it would force a post (with only 1 RAM installed, and using a PS2 keyboard) and I could get in and change settings, some people reported that was all they needed to do.
Heres the bad news for me, if I power off the power supply, it doesn't keep the settings.
Some were along the way, I reset the CMOS incorrectly. I moved the jumper but forgot to pull the battery (baried under my video card, I didn't think of it), this appears to have toasted the backup power for my cmos.
Now I'm looking for a solution to that, I'm thinking of running a wire from the battery to the jumper plug to reroute cmos power but though a diode so the normal power on doesn't send a charge voltage back to the non-rechargable battery.
I had left the machine with the cmos jumper removed overnight. I used a voltmeter and found I did have power to the header. Reconnected to jumper and powered up, and posted ok (CMOS settings error but ok), set time and date and ram voltage, shut down, removed power and after several minutes plugged back in and powered up, posted normally and even kept the time and date, so appears to be OK.
I think the CMOS just needed a lot more time to clear.
It's good that you found a solution to your problem.
