P5W DH or BX2?
JustinSane
I think I am going to be upgrading my mobo and processor. I believe I have it narrowed down to 2 mobos. The P5W and BX2. I was leaning more towards the P5W till I read a review tomshardware did. They said they had some probs with it. Does anyone that owns this board have any probs with it?
I have the board and it has been great. I can get to 3.4ghz pretty easy and the extras have been nice too. I didn't read the review at toms so I'm not sure what problems they had. There have been a few bios updates and believe the fixed the early problems, I'm using version 1901 and been very stable.
the p5w is a great board PERIOD. software is fine tuned for the board and bios is pretty simple to use. Overclocking is stable usually.
i heard the BX2 is pretty good also :p
1 vote for the p5w
"The Asus P5W DH Deluxe comes with a long list of features that include virtually anything you can think of. From this point of view it is worth the $269, but since it suffered from teething problems during our tests and didn't overclock as smoothly as other Asus motherboards, we would rather not spend the money on this product."
http://www.tomshardware.com/2006/10/11/four_975x_motherboards_for_core_2_duo/page15.html
This was back in 2006 so I guess maybe Asus got it ironed out?
Honestly, either one is a good board. I think the BX2 is a little cheaper, so I'd probably get that unless you need/want the extra features on the P5W. I've used the P5W for the past 6 months or so and I can't complain at all. Great board. Ran it with Crossfire. Ran it with my 8800GTX. Definitely one of the better boards I've owned.
I suppose if you want the features, go for the P5W. If you want the basics (so to speak) with stability then go for the BX2. I was going to go for the BX2 but now that I saw this thread it has resurrected my P5W vs BX2 in my mind now. :/
Another vote for the bad axe 2. I love it. It got me to where I wanted to go overclocking-wise, and still has room since I havent even pushed it yet.
I have a BX2 ordered. It should get here by Wednesday, but I have a few questions/concerns:
1.) Don't want to deal with any sort of "Mickey Mouse" BIOS. I understand that it has a secret menu that requires setting a jumper, and that that jumper can be tough to access. Is this a concern for any of you? I am coming from ABIT (in the past) and ASUS boards where overclocking is out in the open.
2.) I understand that some of the connectors on the BX2 are in oddball positions. Anyone have issues with this?
Other than that, I look forward to running a stable board. I have a good E6600 that was running happily @ 3.4GHz on a P5W64 fully stock on air until the motherboard went sour on me.
Andrew
The jumper is to access the "maintenance" section of the BIOS, and I only went in there to disable a couple things for my OC, a one time thing. Although I read elsewhere that the things I disabled are never actually disabled yet because of some driver or something, I dont know. But yes, it can be a little tricky to get to if you system is already together. The biggest thing in the way for me was my 8800GTX. But with a little patience I got it.
As for the connectors, the only thing in an "oddball" position I guess you could say is the IDE connector. Its at a 90 degree angle to the board, instead of sticking straight up. But with my full tower case I actually like that, since it makes my IDE cable lay flat with the mobo tray. And now that I look in my case, having a crossfire setup might interfere with my 2 sata drives connected to the Intel controller. Oh well, I dont plan on xfiring anytime soon, and even when I do, I'll figure something out.:p
Hope that helps!
It DOES help!
Thanks very much!!
Andrew
Hope that helps!
I ran Xfire on mine with 3 SATA drives, and it was a little tight. As long as you plan how you want the cables to go, you shouldn't have problems (P5W that is).
If you look at the specs they list they were running a mobo with Bios 0901 (07/24/06) . That was a very primitive BIOS that I don't even think was launched with retail versions. Bios 1101 was one early retail version and it didn't work with the retail C2D's but only "engineering samples". Asus had to send out new Bios chips or people had to buy Celery cpu's in order to boot-up and change Bios. So 0901 is very early version. I lost a little regard for Tom's when I saw they published a review in Oct based on a Bios well known to be flawed back in July. The Register and other news outlets covered the bad Bios because it was a bit of a fiasco for Asus at the time.
