Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am getting a mobo temo of 40 C and a avg cpu temp of 47 C while running windows... havent tried gaming yet to check it at load... should I be worried? at what temp can I damage compenents?
Are you overclocking, overvolting or both? Did you follow the instructions for installing the heatsink? What temperatures are you getting under load? Have you looked at the other threads talking about Core 2 Duo temperatures in order to compare yours to theirs? If you have a retail CPU and installed the heatsink correctly, I would not be surprised if you were elligible for an RMA through intel, should things go wrong.
