P5Q Pro Major Issue
Cmustang87
Hey guys, I think I posted in the incorrect spot to start with as I'm not getting many responses over there so I thought I would move the thread here.
http://hardforum.com/showthread.php?t=1343913
I really need help with this issue, I'm very confused.
Copy and Paste from original post:
Hey guys,
Last night I just installed Bioshock on my new rig (sig.), then started chatting with a friend on Steam. During the chat session, my computer just reset itself. On POST, I had an error message that said CMOS had reset itself and to enter BIOS to configure the CMOS clock again. All of my BIOS settings had reset to default, so I changed it back and got into Windows (Vista x64 Ultimate). When I got back into Windows it said that I couldn't connect with my network drives and I could not access any of my network resources. I could communicate with the router but I couldn't get the web.
I have Hamachi installed on the computer, but I don't think that has anything to do with this issue. Read on...
So, of course I power cycled the router and my cable modem (the rest of the computers in the house work okay) but had no luck. I noticed that my computer was getting a 169.xxx.xxx.xxx private IP address. So I tried resetting the TCP/IP stack and also applying a Winsock Fix. I rebooted the machine and still couldn't access the internet.
At this point I'm and WTF'ing all over the house. I tried to static my IP address to 192.168.1.15 with my default gateway being (router) 192.168.1.1, but it said I couldn't as there wasn't a network card installed. So I tried uninstalling my ethernet card driver, but my OS doesn't want to do it, it just locks up and won't continue with the re-install.
At this point, I'm like... OK I just installed this OS on Friday and spent the hours that it takes to get it up to date and installing the software that I want on it. I really don't feel like re-imaging it, so I try to use the System restore built into Windows, and I tried to reset it to the point right after I installed BioShock, but when it says Windows is Shutting Down, it just hangs there... doesn't actually shut down or reboot into the system restore menu.
Seriously, am I just fucked and need to reimage this computer even after a few days of use? What am I missing here? :confused:
I'm not sure about some of the issues you are having, but from my experience with himachi, it sounds like that's where the private address is coming from.
Sorry if I'm not much help.
Might want to disable or uninstall it and see if it clears that issue.
GL =/ Hope you can figure it out.
