I have a pc with an E4600, 4 g's ram and an Asus P5Q-E motherboard.
I also have an optical drive that connects to the mobo via a SATA connector.
I've been using XP Pro on a WD 1T hard drive.
On May 5th I installed Windows 7 onto a WD 640G hard drive.
With my skill level, not dual booting from a single hard drive can only be a good thing.
According to some generic instructions I found online, I should be able to press F8 when I power up the pc and choose which hard drive to use.
What a surprise. It doesn't work as advertised.
What I see in the boot manager is the DVD, 1 hard drive and a floppy drive. I don't have a floppy drive.
But the boot manager tells me that when I connect the DVD to the mobo using SATA that the non-existent floppy appears.
Would somebody please tell me what connectors go where?
At best I'm looking at a bunch of red and orange connectors.
I have not a clue as to which ones to use.
Really people. I need help.
Thanks.
Hugger
Thanks.
Hugger
