P5N32-E will not post?
Zhyn
I just got another P5N32-E in again ( I destroyed the last one..) And my computer will still not boot/post/start up at all. Pressing the power button causes all the fans to move an inch, that's it. No noise. Nothing powers up. The led on the mobo is on. I don't know what could be wrong. My system specs are in my signature
Sounds like a case of you having a motherboard mounting screw in the wrong place. Like it is grounding out. What I would do is take the motherboard out of the case, go over where the screws are, make sure there is no metal sticking up, no metal touching any traces/points on the board and screw it back in.
SoulMan901
if that doesn't work I would also suggest assembling the mobo somewhere where it'll make no contact with any kind of metal, like a sheet of plastic or wood. Set it all up, cpu ram maybe not video and see if that works
I also heard of cases like this where someone either put too much stress on the mobo or they picked up their case without the side panel being on...sorry if i didn't make much sense there lol.
if it's the later I would try an return it...
So the only thing I could switch out from my old dell 4300 was the power supply. So I put the cosair 620w into my dell and tried to start it up... annnnd nothing. Just the led on the motherboard lit up =/ Am I not installing this power supply correctly? Or is it just dead?
No I mean assemble the whole thing out of the case...run the CPU with the mobo -outside- the case. That way you can narrow it down to either mobo or psu or both >.<
First test with nothing, except one stick of ram and one hdd and a more than capable psu. If it boots, add a part, like the video card. If it still works add some more ram until it doesn't boot, but only go one part at a time.
Once it stops booting you will have your bad part. If it never boots, try a dif psu and if that doesn't work RMA.
It's not touching any metal, I'm sure of it. And I've test it with removing different parts already. If the psu doesn't work in another computer, I'm certain its the psu. I tried the green wire to the black wire test, and the psu fan doesn't turn on at all. I'm just going to rma it.
Ummm, putting your PSU into a Dell Computer and hooking up to the motherboard made for Dell probably made things worse. The Motherboards for Dell are custom made and don't accept normal PSU's. Now if you want a sure fire way of testing the PSU, go buy yourself a PSU Tester from Compusa or Office Depot. They cost 10-20 and help out a ton to make sure your PSU is working correctly.
SoulMan901
Not tring to insult your intellectual ability, but are you plugging in the other 8 pin 12v plug
