I know it's normal to have a discrepancy between the voltage set in the bios and the one seen in windows (like using CPU-Z). But usually the Bios voltage is supposed to be higher.
My voltages are all over the place.
I am setting my Vcore voltage to 1.4
CPU Z is showing 1.6
Speed fan, and PC probe II are showing 1.55
Is this usually a bios problem? or what??
I am using the latest bios 0901 i think
