P5N-E SLI Issues
bpmurrGT
I'm having a few issues I believe are related to my P5N-E. I did a search but really couldn't find anything related to my problem. When installing Vista Ultimate 64-bit the system seemed to take forever to go between screens so I updated to the 0401 bios via flash drive. Then the system screamed through the Vista install. However I'm having a few issues.
1) In the bios is reporting my CPU (e6400) temp in the 34 degree Celsius range at stock settings. Which doesn't seem right because I'm using the Tuniq tower with the fan speed half way.
2) I can't get any CPU temp or motherboard readings in CPU-Z and the NVIDIA Monitor software.
Is this something any of you guys have seen? Thanks in advance for your help! :)
