P5N-E SLI + E600 + G.Skill PC6400 Questions
Okay I just realized my topic on this was not in the right section so I'm reposting a few questions here.
In the BIOS I have the FSB set to 1200mhz which puts the core speed at 2700mhz.
The memory is at 450mhz (x2) and the timings are pretty bad at 5-6-6-31.
In the BIOS I set the FSB and memory stuff to Unlinked. I'm not sure what you should do for that setting to be honest. The memory timings I left at Auto in the BIOS because I'm not sure what to do with those.
I was able to runt he half hour OCCT test without any problems on these settings. It idles around 37 degrees, which is maybe a degree or two warmer than stock.
NOW.
I tried bumping the FSB up to 1333mhz which set the core speed to 3ghz. 18 minutes into OCCT the computer locked up. I didn't get any error messages, it just stopped responding. I'm guessing this means the overclock wasn't working lol :confused: :D
Now, my question is what should I do to adjust the memory in accordance with the processor. I wanted to try to hit about 3ghz. Should I set it to 1:1? Linked? Unlinked? If unlinked what speed?
Hmmm....I tried to just jump it and go up to 1400FSB
Yeah that didn't get windows to post :D
I bumped it downt o 1350mhz and Windows was able to load but it started stuttering real bad so i just restarted and set it to 1250mhz which lands the core speed at lik 2.81ghz.
try linked and synch mode. that RAM took a ton of voltage to work right when I had that setup and it never clocked very high.
