Hi all, I just upgraded my CPU to a Q9550. All went well until I powered the PC on and it stayed on for a few seconds then shut off. I figured out the problem for some reason my case shorted out my board, well all the USB's do not work. I took off the front panel to clean the case inside and out. I think something happend when I plugged the front panel wires back in. If I turn the PC on and play with the front power wires it stays on, and only stays on the ASUS logo show. All other PC parts are fine, CPU, Vid card etc all fans ok. So my question is Im going to buy the exact same board and and a new case and not install Win 7 again. Hell no lol. Since its the same board all Im going to do is reinstall the mobo chipset drivers, would this be ok?
Thanks
Thanks
