P5L-MX locked CPU multiplier? *PLZ Help*
dualsin
Having bits of problems with an E6600 Core 2 Duo processor and the Asus P5L-MX MicroATX motherboard.
Loaded up CPU-Z and noticed that the core speed of the E6600 cpu is at 1599.9 MHz with a multiplier of x 6.0 and a Bus Speed 266.6 MHz and also a Rated FSB of 1066.6 MHz.
Now, theres a function in the bios called Ratio CMOS Setting and it's default value is 6. Now when you change the value from 6 to 9 (as it should be so the core speed clocks at 2.4ghz), CPU-Z shows the cpu running still at 1599.9 MHz with a multiplier of x 6, as if it wasn't even changed in the first place. If you reboot and go back into the bios and take a peek at the page you were just at it, says "Actual Ratio Value : 6" when just below that, the value of Ratio CMOS Setting is still at 9. It's as if somthing is locking this cpu's multiplier and its making absolutely no sense.
Anyone have any ideas?
All Conroe chips have a locked multiplier, except for the X6800..
Though I wonder why it's at 6 instead of 9.
Did you check under the CPU page where it says multiplier?
Have you made any BIOS changes recently?
What chipset is that board?
The chipset on the board is a 945G Intel.
The bios was updated to the latest one from the Asus site and sadly I didn't back up the original bios because I would of never foresee this sort of thing happening =/
And when it comes down to the CPU Multiplier... the only thing in that realm is what I said in the original post and it's called "Ratio CMOS Setting". :confused:
