Help guys, I think I just hosed my roommate's new machine:
I built it for him back in July - specs:
Asus P5K-E WiFi-AP
Core 2 Duo E6600
2GB OCZ DDR2 1066
BFG 8800GTS 320MB
250GB WD SATA
18X Samsung DVD-RW SATA
Vista Home Premium 32bit
Last week he started getting random crashes in 3D apps (mainly WoW) BSOD stop errors after installing new drivers etc...
Tonight I tried to just clean the system out software & driver wise and make sure everything was in working order and up to date. Noticed his BIOS was a couple versions behind so I dl'ed the newest and ran AsusUpdate. The flash went just fine, it completed and verified etc. Asus Update said to restart, clicked OK, Vista went through what looked like a normal shutdown etc. Just before the reboot should have happened though Vista threw a stop error that said "MEMORY_MANAGEMENT" at the top and then rebooted.
I get no POST screen or video signal of any kind now, the system will turn on, fans power up etc, but it just sits there. I tried clearing the CMOS by taking the battery out and capping the jumper - nothing. Tried reseating the video card and RAM - nothing.
Did the BIOS hose here somehow even though it said the flash had completed successfully? His system worked perfectly fine until about a week ago when all these errors started out of nowhere... Really dreading having to try to RMA it with Asus, it's probably gonna take forever and I'm sure Fry's isn't gonna swap the mobo for us this long after purchase...
Thanks, any help is appreciated!
Asus P5K-E WiFi-AP
Core 2 Duo E6600
2GB OCZ DDR2 1066
BFG 8800GTS 320MB
250GB WD SATA
