P5K-E BIOS revisions
AmongTheChosenX
What is the best one you guys ahve used so far?
What has achieved the highest overclock?
I'm using the PC in my sig below.
1006 sets vcore properly, unlike 0906 which came with the board.
I only have experience with those 2.
0906 had a vdrop on the CPU of like 0.10v
1006 has a much more normal vdrop of like 0.02v
Neither had any issues with vdroop, once load line calib. is enabled.
They both seem to overclock the same. 3.9Ghz (434x9) for me.
Over at xtremesystems.org, almost everyone recommends 1006.
hm.... yeah I think that might be the way to go. the 0602 BIOS seems really old to me (I'm using that now)
1004/1006 has issues with usb hubs, 1002 and prior do not.
I have to connect my G15 and MX518 directly to my computer and unplug the hub on my 2407WFP.
I downgraded back to 503. When the 100x bios comes out without the usb issue I'll upgrade to that.
Do any of you flash from Windows, or is the floppy disk route still the only way to go?
neither.
Put my BIOS on a USB key and use Alt+F2 fto start EZFlash during POST.
DO NOT flash from Windows though, it has a horrible track record, do NOT do it.
