P5K Deluxe bios issues
JohnleMVP
I'm not sure if I'm missing something but I can't change the FSB on my P5k Deluxe. With the stock bios I couldn't manually change the fsb. It would show the option but when I hit enter to change it nothing happened. I updated to the latest bios (0311) and I have the same issues. I can't change the multiplier either. The only way I have been able to mess with the fsb is to set the motherboard to N.O.S. mode and go into windows and use Asus's AI tool. This is very unstable though and it rarely works right.
EDIT: I looked through the manual and I guess your suppose to use -/+ keys not enter. :p
On my P5K Deluxe, I must press NumLock to be able to type in the FSB manually.
(the regular 0-9 doesn't work - only the numpad after pressing numlock)
It took me a few minutes to understand how it worked too!
I was pressing + and - and enter like crazy, and wouldn't see the list of FSBs to select from...
Like calebb said, just type the FSB in with your numpad and press enter.
