P5K and eSATA connection
boxterduke
Hey guys, I have a P5K motherboard and I bought a 2.5 external enclosure to put the 80GB HD I removed from my PS3 after upgrading it to a 320GB.
This is the enclosure and it supports eSATA.
When the PC is booting, I see the hard drive being listed during the POST however it does not show in Windows.
It only shows while connected via USB.
I plug in the eSATA cable to the back of the PC and the USB power cord as well.
I tried all three different settings in the BIOS, IDE, SATA, RAID, AHCI with no luck.
Does that external eSATA port at the back of the motherboard supposed to be used only for RAID while connecting to another drive or can I use it instead of a USB connection?
Thanks
Is the eSATA port controlled by another controller other than the Intel one? (Marvell, Silicon Image, etc). Are there windows drivers for it? Can you see the drive if you go to "Computer Management".
Hi,
I had the same problem and it was the cable/connectors, I tried several esata cables and had to be sure they were seated just right, complete pain in the rear, quit using esata because of it, I think the connector on the P5K is out of spec at manufacturing, you might call ASUS tech support and see if these is a known issue.
Good luck
Yeah it is controlled by another controller (name escapes me)
It does not show in Computer Management.
