airswimmer
- Feb 3, 2008
hi all,
need help on my new PC, my TT Armor Junior case has a front panel audio plug with two heads which marked with "azalia" and "AC97", both will fit into the SupemeFX II card that comes with P5E, I plugged the Azalia head into the SupemeFX II card. now my front panel(for my case, it's actually top panel) audio output has no problem, but mic doesn't work. i tried plugging mic at the back, it works but just very low volume, I have put the mic vol to max. also when mic is plugged into the back, when i mute the mic vol, I can still record with the sound recorder?!?!?
I just need the mic to work properly at front panel socket. any ideas? thanks.
