slugger_2003
- Jan 30, 2007
Which board would you all reccomend and why?
Noob question. What is crossfire capability?
Good choice. Get an Intel E6600 and Asus P5W DH and you can't really go wrong. You don't need to buy a wired network card since the onboard one will do fine. If you get the ASUS P5W DH DELUXE/WIFI-AP (http://www.newegg.com/Product/Product.asp?Item=N82E16813131025) then you won't need to buy a wireless network card either.
QFT
# 3 - 680i - (hit or miss, you MIGHT get things just right or you might hit a FSB hole and not be able to max your OC properly, or you could have one that hoses/corrupts your harddrives.)
So far I love my P5B Deluxe. I've had a couple of oddities, but nothing too extreme.
Sometimes when I change BIOS settings, it reboots as normal (like every other board I've owned) but sometimes it
1. Save BIOS
2. Computer powers off
3. Computer powers on for 1 second
4. Computer powers off
5. Computer powers on and stays on with new BIOS settings
^--- all that is automatic without me pressing any buttons besides Enter to "Save/Exit" BIOS
It's kinda weird but I've heard of it so I'm not worried, it's not like it resets my BIOS settings.
It depends what you want it for. If you want to use nVidia's SLi technology sometime in the future then, by all means, go with the 680i.
I can't really say much more than that without any more information. Are you planning on overclocking at all? What are the other system specs.?
EDIT: I thought i'd add some more information.
P5B is a suitable board for low-end Intel CPUs, since the P965 it uses allows for higher FSB speeds when overclocking.
P5W is more suited to high-end Intel CPUs (E6600, for example), since it uses the older, although high-end, 975X chipset, aswell as Crossfire capability.
That problem with the P5B Deluxe seems to be a regular occurance, sounds like a non-issue to me.
Get P5W DH DeluxeThis is my current thoughts on system specs....
