p5b onboard sound noise
ziddey
Onboard sound in general has always been subpar, but of the few recent motherboards, they were decent enough for what I do nowadays. However, the p5b has really disappointed me. I was getting a hissing and a very quiet popping and crackling with my speakers. I adjusted pci latency between 32 and 64 and more to no avail. Then with headphones, I noticed the buzzing matches up with me doing things on the computer like dragging a window.
Guess I'm going to try taking a qtip with alcohol and just cleaning all around the board to see if it helps with any of the possible electrical noise or whatever.
Anyone else have similar issues? I'm tempted to throw the old sblive value 4.1 back in that I never sold.
I had a similar issue with the P5B Deluxe onboard sound. I first ensured that all the drivers were the latest ones - obvious step. Now for the less obvious:
- Is your JMicron controller enabled? Is it in IDE mode? If so, go into device properties (it might be listed as a generic Microsoft IDE ATA/ATAPI controller, and make sure that the last IDE-connected device has DMA enabled. If you're using it for an optical drive, it'll usually offer UltraDMA mode 4 - check that box.
- Check the voltages on your northbridge and the FSB termination voltage. I found that the system continued to click and pop if those voltages were wrong. Have you got the NB significantly overclocked? (which will happen on a P5B board between 350 and 400 MHz FSB before the 1333 strap kicks in above 400 MHz). If so, your NB and FSB termination voltages are probably pretty high. Not sure what your overall setup is, but make sure you calibrate those voltages. The clicking & popping sound is usually because of an issue where the soundcard - RAM communication is messed up.
- If it still doesn't resolve, get yourself a Creative X-Fi PCI soundcard (I think they're about $60) and just disable the MB audio. You'll also get the benefit of unloading the CPU a bit. If you want to go a bit fancier, get an X-Fi card with onboard X-RAM so that it unburdens your PCI bus.
- Speaking of that, you haven't got your PCI bus overclocked do you? Lock the PCI-E to 100 Mhz and the PCI sync to 33 MHz. You can achieve PCI boosts in other ways with a P5B.
- Also, don't boost the southbridge voltage. Keep it at default. It doesn't need a boost for most scenarios. Overvolting it makes the SATA interfaces too susceptible to corruption.
hmm some good tips. I've been using 110 pcie since a few motherboard iterations ago. Is the soundmax based off the pcie or pci? I'll give it a shot bringing it down to 100.
As for vmch and vfsb, I'm manually setting them to 1.40 and 1.20. My fsb is at 400. I suppose I'll give 401 a shot and see what it does, but until my new ram gets in, I'm preferring 400fsb.
vICH is still at stock 1.057 or something. But vcore sb (pcie/sata) I have bumped a notch at 1.60v since I figured I'd build in a safety since my pcie is at 110. Maybe that's generating the noise.
I'll experiment, but as long as you're suggesting that you've been able to remedy it, I'll put in more effort :)
Also, you using 64 pci latency or 32? I've always been accustomed to 32 until recent motherboards all seemed to default 64.
A few things jumped out at me about your settings.
- Set your northbridge voltage to 1.55v - ie. one down from the max. The chip needs this voltage between 360-400 as it's very overclocked, due to the MB still being at the 1066 strap at those FSB speeds. (Above 401 it drops down again on the 1333 strap).
- Set your Vfsb to 1.4v. Same reason as above. In fact this alone might fix your issues. Try this first without anything else.
- You probably don't need the extra Southbridge voltage, even with your PCIE at 110 (which is really no biggie - if you had it at 130 you'd need some extra juice). I'd suggest setting that at auto.
- Leave your i/o chipset voltage Vich at auto. Haven't noticed that needing any boosting at all.
- I'm using PCI latency of 64. Yes the default has been 32 in the past, but now I also see the default of 64. Remember, this is the setting that tells all devices on the PCI bus if they want to master the bus, that they have to be done with busmastering within a max of 64 (or 32)PCI clock cycles. The larger that number is, the more speedy bus mastering devices can get lots of data transferred - but there's the issue of other devices having to wait too long. Audio devices are generally pretty slow and have ample buffer to last way beyond 64 or 128 or higher without any new data flowing to them from the PCI bus. That won't be causing your audio dropouts. This is almost certainly an electrical problem with bus communication (due to voltage problems), not a data latency issue.
Here are some other fixes people have found:
1) Disconnect your case speaker. Yes, this is bizarre, but it works for some people.
2) Disable DTS in the SoundMax panel.
3) Disable the digital out if you're not using it.
Thanks for the input. I sank down to 1.4vmch and 1.2vfsb after some testing at this setting. At first I used 1.55vmch and 1.4vfsb and static was still there. I'll try turning down vpcie to see what happens
case speaker didn't work :(. dts is off. digital out seemed to work a little bit but I'm not completely sure. I'll use headphones later. Thanks :)
edit: makes sense since now I remember for my laptop, I had to disable the "subwoofer" in the registry and it got clearer.
Check your RAM voltage too, of course. As mentioned I think this is most likely an electrical issue with the soundcard - RAM communication, not a data latency issue. You might try just tweaking the RAM voltage down a bit.
It's definitely something to do with the motherboard. When I have a varying load, especially like when I'm scrolling a webpage, I get a sort of noise from my motherboard itself as well as sound. I noticed this when I had the case panel off. The noise is pretty much in sync with the scrolling. Guess if I ever have the motherboard out again, I'll think about giving it a possible alcohol bath.
My p5b-deluxe does this too.
I had to re-ground the case to earth to get it to go away, and put it on a different circuit than my speakers.
Surfing webpages, minimizing windows or using the "mouse scroll" for anything would cause a high-pitched whine.
You can still hear it if you REALLY try.
How did you reground case to earth? When I do testing, case is definitely grounded relative to motherboard. Not sure how well though but motherboard ground points to far corner of case read out 3 zeros for resistance when I try.
Speakers on different circuit, that one would be tough in my apartment. And that doesn't solve the problems with headphones
edit: All in all though, I'm almost completely satisfied with my p5b vanilla. I'd rate it 100x better than the three ds3's I've used. Now if only I could figure out a vdimm pencil mod.
