P5B DLX + E6600 + OC = 3Ghz?
acaurora
Okay, so I decided to be a little adventurous and do some OCing... I managed to get the advertised 4-4-4-10 timings on my RAM, which is actually now running @ DDR2 1000 (500 Mhz @ 2.10V), and the CPU is hitting 3 Ghz. My question to you all is... does this all sound right? Am I doing anything wrong? I have been running F@H for only a few minutes, and the temps on both cores is staying around 50-53C!! I'm normally used to seeing temps of only like 40-45C. I'm using an XP120 with a Nexus 120mm fan (slow spinning), and I want it to stay that way (being quiet). Is there anything you guys would recommend? Also, for some reason despite me disabling SpeedSTep in teh BIOS the CPU speed still goes down to 2Ghz when idling. Anyone know how to fix that?
XP120... with a low speed 120mm fan and of course AS5. At what temps should I start worrying about it getting *too* hot?
I have the same motherboard as you and the E6600. I have mine on a stock cooler at 2.6Ghz idling around 42C and hitting around 60C at full load. You don't have to start worrying about temps until they get around ~70C. Anything above 80-85 will damage your processor.
Meh I dont know. I've always been told 60 is the worry point. I will run @ stock speeds for now, I've ordered an Antec 900, hopefully the gigantic 200mm fan will help with temps... i'll OC again when i get it (in about 2 weeks ;) )
You're temps are fine. At stock C2D run reall cool, but once you start OCing the temps go up. I have a P5B Deluxe w/ an E6600 Running @ 3.4GHz (1.485vcore in BIOS) and it idles at around 43c but goes to 60c @ load. Granted it's running NOT 100% all the time so I'm not worried about it. I'm Using the Scythe Infinity for cooling.
For stability, how much voltage should I be givign to the CPU if I am to run it @ 3 Ghz? I let it stay on Auto when I was OCing it.
Of course every CPU is different. I would try 1.400~1.450 first. Then take it from there.
