P5B Deluxe/Wi-Fi Help Please
SoulForge
I am having a problem with the new computer I built. . . First, it only POSTs about 90% of the time. Second, I finally got Windows to start installing on one of the Raptors, but when it got to the "registering components" part with about 16 min left on the install, it locked up. I turned off the comp and back on and could not get it to POST in a couple attempts. It was late, so I had to call it quits for the night, but would like some thoughts on what you all think is causing the problem. I have only tried the Windows install the one time so far.
I have the following system:
Intel E6400
Asus P5B Deluxe/Wi-Fi
Corsair XMS2 CM2X1024-6400C4 (2x1GB in A1 and B1 for dual channel)
WD Raptor 36.2 x 2
WD Caviar 320 x 3
ATI X1900XTX
EDIT: Oh yeah, and according the Mobo Manual, Asus EZ Flash 2.0 will allow me to flash the bios from USB device . . . i tried it, but it could not access my flash drive (even though it showed up in the bios USB device list). Does it have to be a USB floppy drive or something? or was the manual mistaken?
Thanks for your help!
What BIOS version are you running? Which controller are you using the Raptors on? Are you using the JMB363 or the ICH8R for your drive?
If you are using the JMB363 I'd advise you to stop. The Intel ICH8R outperforms the JMicron controller and the drivers are going to be a bit better with the Intel solution. Your problems may be solved if that is the case.
If not, then there are some settings to look at in the BIOS, and other questions to be answered as well. For instance: What power supply are you using? What is the wattage of said power supply? How many amps on the 12v rails?
I am running 0614 (i think). It's the default that shipped with the mobo and had a date of July 14 or so on it. All HDDs are installed on the ICH8R controller in SATA1-5 ports. The Raptor I am installing the OS on is connected to the SATA1 port.
Didnt want to have the SATA cable running to the back of the machine (it was only one port and too close to the video card imo), so I am not using the JMicron controller at all.
My PSU is a RAIDMAX RX-630A ATX12V/ EPS12V 630W Power Supply. From the specs: "+12V1@18A, +12V2@16A, -12V@1.0A". Since I am at work right now, I will have to check the "actual" amps on the 12v rails in the bios when I get home. By the way, I havent played with anything in the BIOS so far except to change the boot order so I can boot from my Windows installation CD.
When you did the review, did you flash the BIOS with a floppy drive or USB key? If the USB key will not work, does that mean all USB devices wont either (I have a USB floppy drive lying around somewhere). Otherwise I might have to "splurge" on the wonder that is an internal floppy drive.
I flashed it using the floppy drive. I have one specifically dedicated to the reviews and since my test subjects are always on an open bench, it just makes sense to use it. An external floppy should work fine though, most motherboards have full support for it.
I used my usb camera built in memory to flash the ASUS P5B so it doesn't matter long as you format the USB device...
If your system hangs manually set your ram to manufactured timings and voltage... Either it's your memory or your generic power supply.
Raidmax is usually cheap power supply
Other than manually setting the memory settings, is there anything else I should check on in the BIOS?
don't overclock first... Make sure you have stable system...
lock pci 33
lock pci frequency 100
disable both EIST and C1E
disable virtualization
everything else default
If it fails do some memory tests... if you pass mem tests go with a different power supply
This is probably a n00b question, but what kind of memory tests can I do if I cant get Windows to install?
OK so i have some more information now. . .
The Bios that came with the board is 0703.
I was having the "fail to POST" problem that i have been reading about with the sticks in A1+B1 and A2+B2 (for dual channel).
I put both sticks into A1+A2 (single channel) and it has been stable ever since.
My thoughts are that either the memory is bad and will only run in single channel, or the memory slots on the mobo are bad.
Any thoughts?
