P5B Deluxe Upgrade?
carbon12
Just wanted to get opinions on weather it would be worth it to swap out my p5b deluxe for a dfi 965s dark or even a Commando (should I have the money)... what are the pros and cons of updgrading to either? I plan on keeping the same components I have in my sig, except for I may upgrade to an 8 series card later on this year. Thanks in advance.
-RC
-RC
why in the world would you do that?
the 965s dark is a budget board, although it has high fsb capabilities, it'll be a downgrade
the commando is nothing but a spruced up version of the p5b dlx, if you need the bells and whistles then fine
but its a complete waste of money and thought in my opinion unless your p5b dlx can't do over 450fsb, which I highly doubt
why would you upgrade to the same chipset?
ahhh... thanks, didn't know the dfi board was a budget board. As for the commando, it is a very cool looking board with a great layout, though I would've thought with such a high price tag, it would offer a more stable, more tweakable, cooler running board with more headroom for overclocking. The reason I was asking is because I may be building a system for a friend, so I was going to replace my 6300 with a 6420 or 6600 and then possibly get an even new 965 board to replace a my p5b deluxe. So now, if it's not much of an upgrade, then what do I move on to? Don't think I'll need sli, and I've had a good experience with the 965 chipset, so I thought that there would be an "ultimate" 965 board out there for me. Can you point me in a good direction? Thanks.
-RC
you have a P5B Deluxe.. Why would you want to buy a new motherboard? the one you got has put out the highest benchmarks when coming to overclocks..
Seriously. My P5B hits 512fsb no sweat.
Hell, I haven't even had single hiccup with anything before 512fsb. 513 is a different story :p
I would say scrap the motherboard upgrade and spend that money on a faster GF 8 series card. You will get more performance that way.
-RC
the 965 chipset is best for overclocking CPUs with low multi because of their high fsb scaling
the commando is the nicest p965 board out now but upgrading from a p5b-dlx is a waste of money
if your upgrading your cpu then you could upgrade to 680i but you dont need SLI
i would wait for the P5K-DLX from ASUS, its the new Bearlake P35 chipset based on the 965 but with 1333mhz FSB support
http://www.ewiz.com/detail.php?name=MB-P5KDLX
Exactly what this guy said. Its a DDR2 mobo, so you can just transfer your ram directly. It will also support the future Penryn Processors that come out in the future.
Just so you know, all asus 965P mobo's support 1333FSB. So ss of now, your mobo supports future 1333FSB but might not support the Penryn 1333FSB Processors.
Penryn will use the 775 Socket, and 1333FSB but the massive die shrink could cause some voltage complications with older motherboards like the PB5 and Commando.
I have a Asus Commando, I must say I love it. But mainly in a superficial way. I like who the SATA plugs are facing sideways, I like the look of the solid state capacitators, and the aesthetic look of it all. It really has a great layout all around. My cable management is great. The LCD Looks cool, but i NEVER USE IT!
I would wait until a Commando-esque version of bearlake comes out, so you wont feel the need to upgrade from the P5K version once something like the ASUS RAMBO comes out hehe.
Good luck man! :cool:
Thanks for all the advise guys. I just thought I might use some of my current mobo and cpu to make a system for a friend of mine and the money from that would give me a chance to try something better or new... but it looks like what I have right now seems to be good enough, an I should just build him a similar system from the ground up (or wait for the next best thing, p5k commando version). Still the current commando is sooooooo sexy. Thanks again.
