P5B Deluxe, no post
I think I am going to leave this all up to the pros next time bc after this system build I think the PC gods hate me!
So anyways, after figuring out that I got a bad board I sent it to ASUS had them fix the issue, and they sent it back to me. So woo hoo, finally I am going to have my new puter up and running. I put it all BACK together, smile as I am ready to finally have my new system up an running, and all the fans come on, which it would not even do for me last time, and i smile, and wait for the thing to post and of course, another kick in the jewels.
system specs:
P5B deluxe mobo
e4300 cpu
2gig super talent memory
550w Rosewill psu
7800gt
two 320gig seagates (sata)
lite-on dvd-rw (ide)
lite-on dvd player (ide)
I know I am not the sharpest tool in the shed when it comes to system builds or computers in general, but it is not like i am a rookie to this. I have exausted my little knowledge in this subject and if anyone could help... PLEASE HELP!
No beeps or anything similar?
Does it sound like your HD's are spinning up? I'd suggest not hooking everything up and trying it out with the bare minimums hooked up. I'm not sure if any of the P5B's have onboard video, but if yours does you might try using that.
I know a bad video card will often power on but just sit there.
One more thing to check - how well is the board attached to your case? Do you have a screw in each of the mounting holes? I know it's random, but a few years ago I couldn't find my problem for the life of me, but as it turned out, I'd just forgotten a mounting screw. It actually had your symptom, which is why I mention it.
thanks for the quick responce. I was actually pretty anal this time about mounting the board to the case, so yes, they are all there and tight. you are right about there being no onboard video, and not having any friends in the area that are into comps, no extra pci-e cards lying around to try.
something i just remembered is that there is no case speaker, but if i recall correctly the board speaker is what actually beps at post. In answer to you other question, the only sound is the silent hum of fans... i even get the red LED that ASUS has on the P5B's to show a system power up.
Also, everything starts up just fine as far as drives... i just had to try restarting my comp bc the new seagates are very quiet, but it ran and my cd-roms are spining or at least checking as well.
:( there went what little hair i had left.
there should not be a speaker on the mobo unless asus put it on there, and you don't have a pci video card laying around, it doesn't have to be pci-e
no agp on board and the board does have a small speaker. I will see if i can pilfer an old pci card from an old work comp. I just do not even have any friends with a new enough comp to run pci-e to test the vid card... my luck
That sounds like the 1.8V memory problem to me, look it up.
Its a problem where good (higher voltage) memory doesn't post the system b/c it doesn''t get the voltage it needs. The P5B has a SHIT POOR way of initializing the ram. Most people buy a crappy stick of 1.8v 512mb (no smaller!) and using that to post and set the ram voltage higher.
check your motherboard power connector, sometimes psu's have a weird connector that allows the extra 4 pins to get turned in an incorrect manner but they still plug in
you also might try taking out one of the sticks of memory and see how far that gets you
Something similar happened to me when I reseated my HSF.
Pulling the cpu out and reinstalling seemed to fix it for me.
Dunno why it worked though
thanks again for the replies... as for the trying it with one stick, i have tried every combo that i can. No help.
As for the memory problem, I was just reading about similar issues from others right before i checked the forum again. It stinks to think i have to buy a cheap stick to get a system to post, but i guess i can order and return it (restocking fee though) or try it at a local store. I have only played with OC'ing my pcu and gpu... would i be able to increase the voltage on a cheaper stick of memory (rated at 1.8 and push it to meet my dual channel mem)? At that is it even worth the slight mem increase to loose my dual channel?
again, thanks to everyone for all the suggestions!
