StudioXcel
- Aug 23, 2006
Okay... Here's the problem. I have my new-ish rig and I am starting to overclock it. You can see the setup in my sig, but basically it's E6400 on P5B Deluxe, with OCZ Platinum DDR2-800 RAM. At stock speeds, the system is Orthos stable for several hours, but when I bumped it up to 400 FSB (3.2Ghz), I get memory errors, despite it running at stock speeds (at a different ratio mind you). When it's overclocked, the NB heatsink/pipe is almost unbearably hot, while my CPU temps are maybe 4 degrees hotter than stock load. Does anyone know if this is an issue with this (or similar) motherboards? I have heard C2Ds in general are killer on the NB, but would that account for system instability?
As an idea, I am looking it watercooling, and I'll add another block on the NB if need be. The heatpipe goes to another series of fins, which appear to be cooling the MOSFET (I believe). Do I need an additional cooler for it, or is it fine without the heatsink above it.
