p4pe-x, need some help.
Porphyria
TAKEN RIGHT FROM MY ASUS HELP DESK - Submition
I need some help..
Alright well I'm using the p4pe-X with a 2.4b pentium 4.
Problem:
When the "retention" mechanism is fully installed and is pushing down on the chip ( and motherboard ) , so it is fully locked, the computer won't even start. When it's just latched in and not pushed down on by the tightening mechanism, the computer boots. Problem is, the motherboard seems to think that the CPU is running at 100 celsius and shuts off promptly. So lets say I enter BIOS promptly after starting up, goto the temp meter for the CPU in the BIOS, and its going up 2C every second. I believe the temperature monitor is somehow incorrect, and I also don't understand why I can't start the computer when the retention mechanism is fully installed. (The computer shuts off after the degrees of CPU reaches 100, and so I cannot even begin to use my computer.)
Also I know the temp is incorrect because, immeadiatley after the computer shuts off I took out the CPU, and it's cold.
Any help?
