P4P800 System Failed CPU Test w/ 2.8 C
Vs17
Yeah I was wondering if anyone could provide any type of help with my problem. I recently bought the P4P800 Deluxe mobo with a 2.8 c and 1 gb of Kingston Hyper X Pc4000 (sig). Anyway I started off modeslty, got it up to 3.4 and after about a week I settled on 3.2, which was stable and good through hours of prime95. Im using a great air cooling with some Arctic 5 system that kept the temps on the CPU (even when overclocked and loaded) very cool according to MBProbe (28 idle, around 38 Load). Anyway I was listening to some music the other day before starting 2004 when the system froze. I rebooted and came to the Asus AI screen which said I had an overclocking error, however it froze there. Did a cold reboot and now nothing will work, I get no screen output and nothing loads. Ive tested everything out on other machines, the 9800 pro is functional, the ram is good, and its not the harddrives. I hooked my speakers up to the onboard audio only to hear the "lovely" voice of my motherboard screaming "System Failed CPU Test". So i'm stuck with a busted comp waiting to get back to my precious UT04. Ive only been running the 2.8 overclocked for about two weeks at most 4 hours a day and some days 0.
Could I have already burned out the CPU and need a replacement or is there something i can try with P4P800 to make sre or fix it? and if i do need a replacement will I be able to rma it to newegg after a month or get intel to send a replacement, or am i sol? (any replacement suggestions if not the 2.8C)
Sorry for the long post but Im thoroughly pissed, thanks for any help
