P4P800 Sound related issues?
napsterhaven
Ok since upgrading to this new mobo(p4p800), I cant get TV wonder to record the sound correctly. Ok lemme give you a run down of what I have tried. First and for most every driver and bios is the most current version. I am also using SoundMAX. When I have the playback on LINE IN it sounds crystal clear. However when I have the playback and record BOTH on and in line in I get a BAD!! echo. Is this how its supposed to do?? now theres is another option on connection using the internal audio..also know as the cd in. When I RECORD using this the sound is utter shit. distorted, crackling and no matter how high the record volume is I can barely hear it on playback. I can RECORD to the line in, and as long as the playback in anything other that line in the recording is fine. The down side is the audio I hear while watching/recording is utter shit, distorted, crackling.
What am I missing? I know theres gotta be a easy way to fix this!? Will I need to purchace a stand alone sound card? I currently have a 4.1 setup and when I am forced to use the LINE IN for the recording I lose my rear speakers, which blows. Please help me figure this out!! Is there something im missing with the internal audio connection? I really need to have my line in for rear speaker use.
Before I upgraded I had a A7N8X and when I recorded with the TV wonder the sound was fine. Now I cant get it to work right.
you have to mute the other input. the tuner is picking up sound from both sources which causes your echo.
what he said, i think that should fix ur problem
i couldnt get my sound to work right on the a7n8x, and when i did get it working i still had some problems. muting one source fixed the problem.
now i have a p4p800, but i had to return my remote wonder card so i could afford the p4p :( lol
